11-14-2007 02:30 PM
11-21-2007 02:08 PM
Hello everyone,
We've continued our testing, and as mentioned in Michael's post earlier, we
have been able to reproduce CPU loading similar to that seen by Geir when using
his example code. After including the ini tokens that Michael provided in
the previous post the increase in CPU usage was approximately 15% (24% CPU load
in LabVIEW Real-Time 8.2.1 and 39% in LabVIEW Real-Time 8.5).
In addition, we have found that some of the performance issues may be
specifically linked to reading from and writing to digital inputs and outputs
via the FieldPoint API. If you are experiencing this issue, please
contact your local AE department. They will be able to provide a
workaround for you.
We will continue updating this forum as we continue testing. If you have
any additional questions or concerns, please contact your local AE department
or reply to this forum.
11-28-2007 03:31 PM
CAR 4EUGC7X6 - FieldPoint VIs Run Slower and Increase CPU Usage (8.5 vs 8.2.1)CAR 4F4IN39A - Default value of INI token causing 2 - 4% slowdown.
CAR 4FEFCU00 - Embedded Digital Read/Write is slower in FP 6.0 than in FP 5.0.1.
CAR 4FD7TN1R - Performance Degradation In LabVIEW 8.5.
11-28-2007 04:30 PM
Roy F wrote:
For tracking purposes, here are some CARs that have been reported to R&D so far as part of troubleshooting this problem:CAR 4EUGC7X6 - FieldPoint VIs Run Slower and Increase CPU Usage (8.5 vs 8.2.1)CAR 4F4IN39A - Default value of INI token causing 2 - 4% slowdown.
CAR 4FD7TN1R - Performance Degradation In LabVIEW 8.5.RoyP.S.Info and work compliments of Ching and Michael (and others). I just want credit for posting the CAR numbers. 🙂
11-29-2007 01:30 AM
Hello Geir!
Whenever a bug is reported we write a Corrective Action Report (CAR) or a bug report if you like. In LabVIEW 8.0 for an example we didn’t publish the bugs that have been corrected or known issues and how to get around these. If you on the other hand look in LabVIEW 8.5 Readme file you will find a subset of issues fixed between LabVIEW 8.2.1 and LabVIEW 8.5. Note that this is not an exhaustive list of issues fixed in the current version of LabVIEW. You will also find a list of known issues still present and possible workarounds. Now when you have access to the CAR ID, you can use it in order to track when the issue will be fixed.
11-29-2007 09:54 AM
Jimmie A. wrote:
Hello Geir!
11-29-2007 11:00 AM - edited 11-29-2007 11:04 AM
Hi Geir,
Jimmie's reply should have read;
"Now when you have access to the CAR ID, you can use it in order to track if the issue has been fixed in the most recent release."
The AE's have access to a report that tells them about what is planned to be fixed in which version.
See here for a list of the bugs fixed in LV 8.5.
Ben
11-30-2007 06:00 PM - edited 11-30-2007 06:03 PM
geirove wrote:
...Where on NI's site do I track this CAR Ids ? I have searched for them in vain.
Roy
01-24-2008 03:14 PM
01-25-2008 07:28 AM - edited 01-25-2008 07:30 AM
Thank you for the update and exceptional support you have provided on this issue!
You wrote;
......internal investigation closed.
....(4HNCF7CY CAR ID) for further investigation.
Please clarify this apparent contradiction.
Ben
