Serial using Labview + FTDI RS232 adaptor
Hi there,
I'm running into a problem, and I think it's probably a simple solution. Maybe you can help?
I'm trying to interface with an Alicat M series gas flow meter (manual here) using an FTDI RS232 cable. According to the flow meter manual the serial settings are
Baud: 19200 (default; others can be used if the computer,
its software and the meter are set for the same rate)
Data bits: 8
Parity: none
Stop bits: 1
Flow control: none
Using PuTTY I can send a command and receive a response (so the cable and the device are working as expected).
In LabVIEW I'm getting the error
Possible reason(s):
VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
I've tried connecting the Tx and Rx pins on the end of the RS232 connector and LabVIEW successfully echoes back the data.
I've tried the different permutations for setting the "Termination Character" and "Enable Termination Char", or alternatively adding "\n" to the string to be sent.
I'm not sure what else to try. I've attached a .vi here that I'm using to try and get a response from the device. Any suggestions?
Tom
(3,289 Views)
That error can appear if you have termination character disabled and are trying to read a fixed amount of bytes that's greater than what the flowmeter sends within timeout frame.
Eg.: if you have timeout set to 1s and flowmeter sends 100 bytes per second, but you are trying to read 128, you get that error.
I can't open your VI due to higher version, to check if that's the case.
(3,281 Views)
I can't see what you are doing wrong because you are running the newest version of LabVIEW and we have frozen on LabVIEW 2021 due to NI's new "pay us forever" licencing model introduced with LabVIEW 2022...
Anyway using an FTDI serial adaptor with its Virtual Com Port and VISA is no different than any other serial port.
Most serial communication problems can be solved by watching this video. VIWeek 2020/Proper way to communicate over serial
=== Engineer Ambiguously ===
(3,270 Views)
Ah I see - I've got screenshots here for the vi. I don't think I'm doing anything special - I just took the "simple serial" example project, added a few extra indicators and changed the data being sent to a command from the flow meter's datasheet.
I will review the video, thanks for the recommendation.
I also tried using the continuous serial example, but it has the same error.
As a temporary test to see if this is the problem, if I expect to receive 50 bytes, and set the "byte count" for the Read vi to be lower than that (e.g. 5), should I expect it to successfully show me those first 5 bytes that I was expecting? I did try this, but it had the same error.
Tom
(3,258 Views)
Accepted by topic author NC_
1. Your termination character is wrong.  The flow meter uses a Carriage Return (0xD), where you are using a Line Feed (0xA).
2. Before your VISA Write, concatenate a Carriage Return Constant to your command.  This will make it so you do not have to worry about the termination character when you are typing in your command.
(3,245 Views)
These are my settings for Alicat MFMs
To get info you need to send the device ID and a carriage return character, before reading a response, although i'm not sure if this is flowmeter thing or breakout box thing. I see you are sending 'a' command, but i don't see the carriage return, which might be why you aren't getting a response.
(3,199 Views)
I knew it was something simple! I changed this and it's now working. Thanks for the help.
(3,160 Views)
