Serial communication crashes with blue screen
What is LV's memory consumption doing while its running?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 13
(2,993 Views)
Thank you all very much for your help so far. I was able to get access to a PXI system running WinXP. After connecting the instrument to the on-board serial port of the PXI system and running the test vi at a loop rate for 10ms for over an hour, the system did not crash. I am now pretty sure that the driver for the serial adapter that I am using is not fully compatible with Win7-64bit even though they claim it is. I also tried out other USB-serial adapters and one seems to be working fine so far. I think, we can close this thread.
Thank you again very much for your help.
PS: In this application, I am looking for a terminal character to appear and set the byte count to a large number. The expected responses are never larger than about a dozen bytes.
Message 12 of 13
(2,979 Views)
I stand corrected over using a term char and a high byte count. I've learnt something new there.
Message 13 of 13
(2,960 Views)
