Serial Communication
Hi Alll....
i am having a DAQ 6024 E card.My application is to make a RS485 (Baud Rate of 9600 bps) signal using DAQ AO output channel.is it possible ?
(3,893 Views)
The spec sheet lists a 10kHz update rate and 10V/µsec slew rate, so you should barely be able to do this, provided the current and voltage ranges are also appropriate.  You may need external buffering,  depending on your load.  You may also need an external timing source to get the data rate correct (E-series boards do not have infinitely variable timing).  Check the board specifications for details before proceeding.
(3,882 Views)
Why would you spend so much time doing the software when RS-485 converters are so cheap?
(3,872 Views)
its ok.....i would go for lesser baud rate.....but  here are some of my doubts...
1.if i have to write a string say "HELLO" the DAQ write accepts only numeric inputs..means voltage levels...so how can i convert the
   string to corresponding voltage.
2.How to link the baud rate,parity,stop bits and all to DAQ write...
if some one has got any idea or any links that could be helpful...just post it....
(3,870 Views)
I have to concur with Dennis. Why are you going through all that effort? Is this a specific task? Is it a learning project?
(3,866 Views)
The easy way to convert the text i assume is using the bit patterna and a 0-Max voltage as indicator. If you wanna go somewhat more advanced you can combine 2-8 bits into one voltage if you can read with enough accuracy.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,851 Views)
