‎04-11-2011 06:40 AM
Hi Alll....
i am having a DAQ 6024 E card.My application is to make a RS485 (Baud Rate of 9600 bps) signal using DAQ AO output channel.is it possible ?
‎04-11-2011 07:32 AM
The spec sheet lists a 10kHz update rate and 10V/µsec slew rate, so you should barely be able to do this, provided the current and voltage ranges are also appropriate. You may need external buffering, depending on your load. You may also need an external timing source to get the data rate correct (E-series boards do not have infinitely variable timing). Check the board specifications for details before proceeding.
‎04-11-2011 10:12 AM
Why would you spend so much time doing the software when RS-485 converters are so cheap?
‎04-11-2011 10:16 AM
its ok.....i would go for lesser baud rate.....but here are some of my doubts...
1.if i have to write a string say "HELLO" the DAQ write accepts only numeric inputs..means voltage levels...so how can i convert the
string to corresponding voltage.
2.How to link the baud rate,parity,stop bits and all to DAQ write...
if some one has got any idea or any links that could be helpful...just post it....
‎04-11-2011 10:18 AM
I have to concur with Dennis. Why are you going through all that effort? Is this a specific task? Is it a learning project?
‎04-11-2011 11:02 AM
The easy way to convert the text i assume is using the bit patterna and a 0-Max voltage as indicator. If you wanna go somewhat more advanced you can combine 2-8 bits into one voltage if you can read with enough accuracy.
/Y
