Serial Communication Problem
Here's a print screen of the PortMon of a command that I send, the front panel and diagram of my modified Serial Communication.
I get the right answer from the query, but you can see that the timeout came at the reading.
Have you ever see something like that?
Francis
Message 11 of 16
(1,382 Views)
Don't set 'enable termination character' to False. The property that is being set only applies to reads. You want to stop the VISA Read when it sees the LF character. Otherwise, you need to moify your program to see how many bytes are available and pass that to the VISA Read.
Message 12 of 16
(1,371 Views)
Indeed. StarFiber: I explicitly said to set the "write" one, not the "read" one.
Message 13 of 16
(1,361 Views)
It works fine now.
Francis
Message 14 of 16
(1,347 Views)
my god, why i can not lauch a topic?
Amanda
Message 15 of 16
(1,287 Views)
Well, you did but you did not post a question. Have you tried clicking on Help (same line as your user id)?
Message 16 of 16
(1,277 Views)
