Serial Acquisition
I need to develope a PDA application where the PDA acquires the data from a serial instrument, performs some statistical analysis  an sends the results to a workstation PC via bluetooth. Is it possible to use some kind of usb-sd /rs232 on the PDA?
thanks in advance
prof. Fabrizio PATANE', PhD
fabrizio.patane@uniroma1.it
Department of MECHANICS and AERONAUTICS
University of Rome "LA SAPIENZA"
Tel 0039 0644585585
Fax 0039 064881759
Address EUDOSSIANA 18 ZIP 00184 ROME, ITALY
(11,332 Views)
Hello Fabrizio,
Here is some info. that can help explain connecting to a Windows
Mobile PDA
( http://www.appliedpda.com/Products_PocketDAQ_connections.html )
Depending on the device, you can have multiple serial rs232 options.
Hope this helps. 🙂
Sebastian Dwornik
Applied PDA Software
www.appliedpda.com
On May 3, 10:40 am, fabrizioITA <x...@no.email> wrote:
> Hi, I need to develope aPDAapplication where thePDAacquires the data from aserialinstrument, performs some statistical analysis&nbsp; an sends the results to a workstation PC via bluetooth. Is it possible to use some kind of usb-sd /rs232 on thePDA?thanks in advance
> fabrizio.pat...@uniroma1.it
> Tel 0039 0644585585
> Fax 0039 064881759
(11,310 Views)
Hello Fabrizio,
take a look to this document which deals with serial communication and PDA module:
How Do I Use Serial Communication On My PDA?
Hope this helps,
Fabio
Fabio M.
NI
Principal Engineer
(11,240 Views)
Thanks Fabio, I am happy to see that the serial communication is actually supported by Labview PDA, unfortunately CF-serial cards are no longer supported by the gratest part of PDAs...
I hope to find a serial cable for  my PDA otherwise I must wait for someone that build a SD-serial card...
(11,142 Views)
What PDA are you using?  I have successfully and (relatively) easily implemented both serial and bluetooth communications using the HP 2790.  You might have to make a custom cable or something along those lines ...
Greycat
(11,102 Views)
