Sequential Case Structures
Dear all,
I'm trying to make a VI that sequentially opens and closes 4 separate solenoid valves; each one triggered by a separate case structure. Attached is the VI I have created so far. What I'm missing is the section of "code" that starts case "2" after case "1" (default). I am relatively new to LabView, so a short explanation or direction to the correct tutorial will be sufficient. Thanks in advance.
Message 1 of 11
(5,220 Views)
I recommend you go learn the State Machine.  You are actually half way there.
Message 2 of 11
(5,209 Views)
Hey! You've attached a screenshot and not the actual VI
But are you trying to get to case 2 when the timer is reached?
Message 3 of 11
(5,165 Views)
Looks inside-out. Try with the case structure on the inside and the while loop on the outside. 😄
Message 4 of 11
(5,159 Views)
Yes, Case 1 will timeout, starting Case 2, which will have a timer, than on to Case 3 and so forth.
Message 5 of 11
(5,070 Views)
So have you flipped it so it is no longer inside out like Altenbach suggested?
While loop belongs on outside, case structure inside.
Message 6 of 11
(5,068 Views)
This is what I tried, but both counters run concurrently, not consecutively.
Message 7 of 11
(5,058 Views)
now all you need to do is add a select to determine if you want to eithe Keep Waiting in this state or move to the next state after the timer expires.
I have no idea what the build array is there for
"Should be" isn't "Is" -Jay
Message 8 of 11
(5,055 Views)
You missed the decision pint.  if the time has elapsed, then move on to 3,  if it has not elapsed then return to the current state.
I don't understand the purpose of building the array of booleans.
Message 9 of 11
(5,053 Views)
great Idea!
Message 10 of 11
(5,048 Views)
