Separate array values.vi
Hi! I‘m newcomer, in labview7.0\examples\general\arrays.llb, there are a example "separate array values.viwhich place can i found this lable. thank you!
Message 1 of 8
(7,376 Views)
Hi hilda,
Do you mean lable " positive array" ? (guessing from attached image)
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 2 of 8
(7,360 Views)
Those labels are typically an Array Indicator given an apropriate name. To create one, either r-click the output of a function and "create indicator" or Create Array indicator on the front panel and place a numeric in it. (if you get a control you can r-click and change to indicator)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 8
(7,341 Views)
thanks for all the responses! my question is what's the differences between two "negative array"?. the first is original  in VI. where can i find it?
Message 4 of 8
(7,314 Views)
Hello Hilda,
Other Negative Array indicator (with zeros at the end) does not hide the trailing zeros? Try Right click->properties->Display Format->Hide Trailing Zeros. Try also change digits.
BR,
Jick
Message 5 of 8
(7,305 Views)
No, it's not about "trailing zeros". I want to know the differences between "[DBL]negative" and "the label of array" in the Block Diagram.
Message 6 of 8
(7,284 Views)
Accepted by hilda
Do you mean placing front panel terminals as icons?
In block diagram: Tools->Options->Block diagram->Place front panel terminal as icons (uncheck). Now, create array indicator again.
Jick
Message 7 of 8
(7,277 Views)
You can also r-click the block and (de)select "show as icon"
/Y
Qestit Systems
Message 8 of 8
(7,242 Views)
