Separate array 2d and save
Hi, I need to get an array of 2 dimensions below and put each variable inside an array. It would separate this array with all information in multiple arrays, with information only from the corresponding variable. In the end I need to save these array.
Array
CU:OK
CU:ERROR
FIBER_C:H
FIBER_D:H
HALOGEN:OFF
THAR:OFF
THAR_T:0
THAR_C:0.66
HALOGEN_C:-0.17
MOTORS_C:-0.12
Message 1 of 12
(4,611 Views)
Hi Rafael,
To me this looks like a text with some linefeeds, but surely not like an "array"…
(You seem to use the colon as separator char, so use ArrayToSpreadsheetString/SpreadsheetStringToArray with colon!)
Message 2 of 12
(4,599 Views)
The array is like this. What I said before was just an example of the message I will receive via serial.
Message 3 of 12
(4,594 Views)
Hi Rafael,
when you have an array of strings you can apply the suggestion from my previous message…
Message 4 of 12
(4,588 Views)
When the message is sent by the serial and transforms it into a 2-dimensional array, using the logic below. I need now to remove each variable from that and save it to another array.
Message 5 of 12
(4,581 Views)
What exactly do you mean by "remove each variable"?  Show us an example of how you want your final array to look.
It sounds to me like you are just trying to index out a column.
Message 6 of 12
(4,569 Views)
It would stay that way. Each variable in an array with its results.
Message 7 of 12
(4,564 Views)
Hi Rafael,
why do you want to place each "variable" in a 2D array?
Please provide more information on how you need all those data!
(I could imagine using a key-value pair table, implemented using Variant attributes in a FGV.)
Message 8 of 12
(4,558 Views)
It was an idea, but it could be in a matrix too, the important thing is to separate the variables.
Message 9 of 12
(4,546 Views)
It appears that you already have your "variables" separated in your third message in this post. Just use the output of your separated "variables" and wire an Index Array to get your individual values/data.
Message 10 of 12
(4,538 Views)
