Separate 16bit hex data
I want to separate 16bit Hex data in groups of 4 bit i.e. if I input ABCD, the output should be A, B, C, D.
The idea I am thinking of is to do bitwise AND and do masking with 0xf, 0xf0, 0xf00 and 0xf000, but I am not able to implement it.
Please help me regarding this.
(2,978 Views)
Hi ravi,
to implement an AND function I would use the AND function:
The loop above shows an alternative way…
(2,975 Views)
Thanks a lot GerdW..
Ravi
(2,953 Views)
Hi ravi,
in my snippet above I forgot to wire a "4" to the FOR loop N terminal…
(2,951 Views)
No problem Sir, I had got you idea and modified it according to my use.
Ravi
(2,949 Views)
