Sending digital output
HI, I have just started using labview.
I want to send [0,0] [0,1] [1,0] and [1,1] thorugh two digital output lines, 1 and 2 respectively generated through loop number 0 to 3. The image is attached.
i have tried using diffrent things but no success. Please guide
(3,435 Views)
There are several examples for writing to a digital port and to digital line.  I hope this helps.  You will need to modify the write for multiple channels.  But it is currently set to 1 channel and that should help you get started.
Let me know if that helps.
Example for writing to digital Port
https://forums.ni.com/t5/NI-DAQmx-Examples/DAQmx-Write-Digital-Port/td-p/3501596
Example writing to digital Line
http://www.ni.com/example/30006/en/
-Matt
(3,412 Views)
HI Matt,
Thanks for the reply.
Although I am trying to understand what u have send, but lt is even more difficult to convert it and link with my VI 😞 Isnt there any simple block that converts boolean array to number to a from that can be sent to output?
(3,389 Views)
On the digital output for line do this.click  On the bottom of the digital write and select digital output/multiple channels/multiple samples. Then create a control for the input to that block ad you can send a 2d array of Boolean. Then simply input the output you want into the Boolean control and select the channels you'd like to output to
-Matt
(3,382 Views)
Alright. Thanks!
(3,378 Views)
