01-12-2019 09:13 PM
Hi everyone,
I have cRIO 9031 and some NI modules such as NI 9234, 9236, NI 9201,...
I want to send collected real-time data from this cRIO to other city for a monitoring task by the internet.
I only know one method using mqtt cloud.
Can I use UDP or TCP for this task??.
AND other solutions?
Any contribution is highly appropriated
Thank you!
01-13-2019 09:19 AM
01-13-2019 09:40 AM
Thank you
I have used TCP communication for transmitting collected data by the internet and I used external IP, the problem was timeout.
As I know that UDP communication is not believable for the quality of signal.
Could you give me a solution in more detail if I use UDP or TCP.
Thank you,
01-13-2019 10:42 AM - edited 01-13-2019 10:45 AM
Hi ductuan,
Most often you cannot directly communicate by TCP: your devices/computers use local IP addresses, but are connected to the WWW (world wide web) using a router which translates local addresses (LAN) to global addresses (WAN). So you cannot call a local IP address from a different subnet that your own…
Can you provide more information about your desired TCP/UDP communication?
Which IP addresses do you use?
MQTT also uses TCP under the hood, so yes, you can use TCP/UDP…
01-13-2019 06:46 PM
Dear GerdW,
I tried to use simple TCP project with Client.vi and Server.vi
I used global addresses (WAN) for 2 computers and these addresses can be found on https://ping.eu/
I specified IP adresss of localhost to client.vi and run both server.vi and Client.vi. This can help me to send and receiver signal
I need a program that can send data over time and I can receiver this signal whenever I want. Can I use UDP communication?
I have to set up this measurement system next month, so I really need your help
Thank you,
01-14-2019 02:54 PM
If you are worried about timeout and basic UDP functionality, I would test a simple UDP LabVIEW program first
I would recommend trying out some of the LabVIEW help examples.
The "Simple UDP.lvproj" is pretty easy to set up and test. Should give you a good idea of UDP performance between your two PCs and should give you a better idea if thats the way you want to go for your cRIO communications
01-14-2019 07:36 PM
To avoid any complication when communicating trough internet, timeout is one thing, the other is the routing and security.
To run different system like if they where local, use a VPN. You might cut the speed, but you have a huge gain in stability.
Benoit
01-14-2019 08:02 PM
Dear,
Thank you for your solution
I am testing this solution. I hope that it will be suitable for my measurement system.
Reagard,
