A VI - current source?
Hello.
How do I create a VI - current source?
(3,083 Views)
Hi Technik,
technical speaking: you need a DAQ hardware capable of current sourcing. Then you create a suitable DAQmx task (for NI hardware)…
Which software do you use? Is this really LabVIEW (as you are asking in a LabVIEW forum)?
(3,068 Views)
I do not need to connect any external equipment.
I need to simulate inside Multisim - LabView VI (virtual tool) created based on the StarterOutputInstrumentV2 template.
Software:
1). NI Multisim (v.10.1.1)
2). LabView (v.8.6)
(3,050 Views)
Hi Technik,
when you just want to simulate a "current source" by its current value then you already got that by using the slide control.
(When you have problems using MultiSim you should ask in the MultiSim board…)
(3,047 Views)
Clarifications:
This is the use of LabView virtual instruments when simulating inside Multisim.
Do you understand the essence of the question?
I have problems Exactly using LABVIEW inside Multisim.
I can't get the current source.
If you know how to do this, please give an example.
(3,014 Views)
Hi Technik,
Do you understand the essence of the question? I have problems Exactly using LABVIEW inside Multisim.
I understand that you have problems with using a LabVIEW VI inside of Multisim.
So I advise again to ask in the Multisim board!
(3,007 Views)
