Sending Struct TCP/IP
if i have a c struct defined like
typedef struct
uint8 test1 :1
uint8 test2 :1
uint8 test3 :6
How do i represent the 1 bit and 6 bit in labview to eventually send it tcp/ip?
(3,255 Views)
That can be done with a character string of 8 bytes.
Take an array of 8 U8's and convert it to a string. That will wire directly to LV's TCP/IP functions.
Ben
(3,255 Views)
If i take an array of 8 U8's and convert it to a string it sends 8 bytes over the network i want to send the struct below for a total of 1 byte being sent over the network. Is this possible?
struct
uint8 test1:1
uint8 test2:1
uint8 test3:1
uint8 test4:1
uint8 spare:4
(3,255 Views)
LV doesn't support bitfields directly. You can either use an array
of Booleans and convert that to an integer, or you can direcely define
some constants and use the Boolean nodes to construct the I8 that you
want to send.
Anyway, send the struct of a byte and a byte are the same as far as
the compilers are concerned.
Greg McKaskle
(3,255 Views)
