Sending GMAIL with Labview Windows 10
I used this vi to send email using labview.
https://forums.ni.com/t5/Example-Code/Gmail-using-LabVIEW/ta-p/3509017
It works on windows 7, but not on windows 10.
These are the error message.
constructore note: Node not supported in current target.
Wire: type not supported in current target
Please advise.
Thank you
(4,252 Views)
Which labview version you are using in Win 7 and Win 10?
follow these steps in the link : https://www.ni.com/docs/en-US/bundle/labview/page/sending-an-email-from-a-vi.html
and this link : https://forums.ni.com/t5/LabVIEW/Send-email-on-labview-using-the-Gmail-Server-TLS/td-p/474461
-Post your vi/snippet along with error screenshot.
uday
(4,228 Views)
Hi Udka,
I have LabView 2015 Service pack 1. Version 15.0.1f1 (32 bit).
I attached the VI.
Thank you
(4,203 Views)
Are you trying to run the VI on an RT or FPGA target? The fact it says 'not supported in current target' makes me think you are. The VI uses .NET which isn't supported on anything other than Windows OS. Your desktop OS might be Windows 10, but do you have the VI under an RT/FPGA target in the project?
(blog)
(4,189 Views)
Hi Sam,
The project is running on RT.
I am not sure what happened, but it did not give me the error message anymore.
I modified the example from labview of sending email using SMTP (Send Email using SMTP Client.vi).
When I run the example from labview, it works.
The modified VI (Gmailtest.vi), it does not work. Not sending any email.
Please advise.
(4,172 Views)
Yes - like I said, the Gmail example uses .NET which is windows only, it will not run on RT. The SMTP Client libraries built into LabVIEW run on both Windows and RT.
(blog)
(4,138 Views)
