ni.com is currently experiencing issues.
Support teams are actively working on the resolution.
Example Code
Gmail using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
Send an email using Simple Mail Trasfer Protocol (SMTP) to sync up with Gmail. LabVIEW still does not interact with email servers that need authentication, but the System.SmtpClient Class does interact with open email accounts.
Description
This VI uses SMTP property nodes in order to write a standard email and send it via a Gmail account.
Steps to Implement of Execute
Prior to running the code type in all the necessary information.
  1. Leave the Outgoing Mail Server (SMTP) as the default name (smtp.gmail.com)
  2. Add your Gmail Account User ID and Password (FYI: The password is not securely typed and can be accessed in a normal text display from the VI)
  3. Enable SSL (This will send the information securely over the internet)
  4. Sender's Email Address: the email address the email is coming from, Gmail Account
  5. Sender's Name: the name you wish to display as the sender's name in the "from" tag on the receiving email.
  6. Recipient's Email Address: the email address of the person who should receive the email.
  7. Recipient's Name: the name you wish to display as the "to" tag on the receiving email.
  8. CC- Optional: If you would like to add an additional receiver or send a copy to yourself add that email address in the CC String
  9. Subject and Body: Work just like a normal email add your desired text of the email.
  10. Attachment- Optional: This is optional but allows you to attach any file to the email
Once the email is created push the Run Arrow in order to send the email.
Note: If you receive Error -1172 with this example, try logging into the Gmail account with your browser.  This error can occur with Gmail accounts that have been inactive for a period of time.  You must log in with a browser and verify CAPTCHA text to reactivate the account.
Requirements
LabVIEW 2012 (or compatible)
Block Diagram
Front Panel
Comments
TiTou
Trusted Enthusiast
Trusted Enthusiast
on
the code is a bit messy but the function it brings is great !
thanks
Epictetus
Antoine Chalons
wbadry
Active Participant
Active Participant
on
Nice Post G-Money. Very Helpful indeed
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
M1014757
Member
Member
on
Hi  G- Money ,
its very helpful
Branson
Member
Member
on
wow, very helpful!
duyson
Member
Member
on
Dear G-money. I am doing  a project about smart house. I want to use your project in alarming through sending a gmail automatically. How can I integrate your VI to my project. My project is measure temperature and auto alarm through email if the temperature is higher than 50(C). Please give me the advices.
Thank you very much and wish you a nice day!
Son
email: tongduysonth@yahoo.com
todd.davis
Member
Member
on
Thanks for developing this.  I am trying to send this via my school's server and get the 1172 error.  I retried with my active gmail account and get the 1172 error as well.  What else could be the problem?
Gregoiree
Member
Member
on
I'm working with Labview 7.0, .Net Framework 2.0 and Windows 2000 Professional.
I tried to do the equivalent .vi on my software but I had a class conflict betwenn NetworkCredential and SMTPClient.Credentials
May be some one has already fix my problem
dannnyds2
Member
Member
on
i would like to use this vi in my uni project if thats ok. its a VAD monitoring system, and in this case it will allow the person to save their readings and email it to a doctor. the main problem is that i'm having a .NET error, its 1172 but i tried logging into gmail and it still comes up. any ideas?
My error seems to be in the Mail Address block for the reciepiant
Dan
dannnyds@gmail.com
StudMuffin
Member
Member
on
Does anyone know how to send Microsoft Outlook Task Requests through a VI?
effgee
Member
Member
on
Thanks for this - can't wait to try it out.
But I can't miss a chance to jump on my hobby horse - images of code are sharper and smaller filesize when saved in PNG (or gif or tif) format; JPG is only intended for photos
FernandoL
Member
Member
on
very good man!!!
si funciona ya habia probado los otros que hay por aca mismo y nada pero porfin salio.... Gracias.!!!
Best Regards.
Ing. Edgar Lojan
IPTN
Member
Member
on
Awesome
SaidElshayeb
Member
Member
on
Gr8 thanks
Lecturer
Machanical Power Department
Helwan University, Egypt
m.meadows
Member
Member
on
Sorry if this is a basic question. Do you know if this vi works on the 2009 OS X version?
TiTou
Trusted Enthusiast
Trusted Enthusiast
on
It doesn't work on Mac OS X because it uses .NET which is windows only.
Sorry
Epictetus
Antoine Chalons
m.meadows
Member
Member
on
Ahh missed that. Thank you.
Brinoceros
NI Employee (retired)
on
Just a warning - According to the MSDN documentation for SmtpClient, any credentials supplied are sent in plain text.  This means your username and password are NOT secure if someone happens to be looking
Brian A.
Arturo_M._Gomez
on
Hey Eric ! how are you, it's been a long time no talking with you. It's a cool example, you save me a lot of programming hours this night LOL
Arturo Gómez | Applications Engineering
Certified LabVIEW Associated Developer
National Instruments Latin America
01-800-010-0793
ni.com/support
Terry_ALE
Active Participant Active Participant
Active Participant
on
Brinoceros, Doesn't SSL take care of encrypting the credentials?
ALE Consultants
Heckler511
Member
Member
on
Sweet!  Thanks for the posting
Brinoceros
on
Terry - you're right, I missed that property being set.  The session does still start unencrypted, but SSL kicks in before the credentials are sent.
Brian A.
Delber1
Member
Member
on
Hey I have been having some issues with this VI in LabView 8.0. I get an error with the smtp client node in the "from" field and LabView says there is a bad terminal or unwired connection. I have a trial version of LabView that can run Gmail86.vi and it runs perfectly fine, but I only have full version of LabView 8.0. Does anybody know how to fix this problem?
Rocio_
Member
Member
on
Great VI. Thank you!
rick s.
Member
Member
on
Very useful. Thanks for the great post!
amitlipman
Member
Member
on
Hey Antoine,
Did you find a way to send emails through gmail using Mac? or email through any other server (using Mac)?
All the best,
Amit
Mr_J
Member
Member
on
Thank you for this vi.
To well close the attached file after sent, just add the Dispose.
it could create problems if you want to delete one of the attachments you sent, in Labview but also if you try to delete it from Windows.
kenes_fusa
Member
Member
on
great vi. thank you!
Hong.Zhang@agresearch.co.
Member
Member
on
Hi Mr_j
Do you know how to receiving email by using Labview?
G-Money
on
Member
Member
on
Hi Grant
I have donwlanded the mailpop70. When run the Mail Browser.vi got error 56 at POP Read to DOT-CRLF.vi.  Please help me.  Thanks. Hong
Member
Member
on
Hi Grant
Your code was working very well for poet 25. But now I have to send email and SMS to port 465.
My setting are:
Mail server: send.xtra.co.nz
Port:465
SSL: on
User name: XXXXX
Passsword: ********
Those settings are working for outlook. But its dont work for your code now.
I have got error message.
Please help me to fix the problems.
Hong
Miro_T
on
Did you check "Possible reason(s)" paragraph in your screen shot?
Also, were there any changes to your .NET assembly ?
razso
Member
Member
on
THANK A LOT!!
MAY GOD BLESS ON U!!
razso
Member
Member
on
did u had solve this problem?
i also get this error after sending a few massage..
AdeLuna
Member
Member
on
Hi!
I can't send anything 😞
i really appreciate  if you could help me
when i'm using the VI an erreos appears me
is the 1172 error, i have no clue how to make it work
please help!
razso
Member
Member
on
1. u need to log in your gmail account
2. go to setting acount
3.click forwarding and pop/imap
4.setting same as picture above...
5. save..
** u need to log in first your gmail account google web before send email using labview.. this labview gmail unable to send attachment..gmail setting.png
JamesXu
Member
Member
on
Hi Grant:
     Thanks for your vi at first. When i running this vi, it almost occurs error 1172. I have logged in my email, but it has no effects. Anyone can help me? Thanks a lot.
Jepz
Member
Member
on
For those who encountered error-1172.
In your gmail account, navigate to settings/security/lesssecureapps and Turn On Access for Less Secure Apps. You should be able to send email without signing in to Gmail.
Jep
HORSZI
Member
Member
on
Hy!
It was great. The help with less secure app. I have a problem, In a running VI I have a continous sign. When it's high, send a lot of mail from "Send email", but I want to receive just one. I tried to solve this problem with loops, but it didn't work. Do you have an idea anybody? So I want to creat from a continous sign to one rising edge.
Thanks the help before!!
Szilárd
lf19902001Wahah
Member
Member
on
Great VI. Thanks!
Thanks, Jepz! That's right solution for the Error -1172!
I found that if you use Outlook.com account, you won't have this problem. Does this mean Outlook.com use less secure sign-in technology compared with google ?
lf19902001Wahah
Member
Member
on
Check Jepz's reply.
jrvinck
Member
Member
on
did you find a soltion for your problem im getting the same error
lf19902001Wahah
Member
Member
on
If you use Outlook.com account, you won't have this problem.
Easterly81
Member
Member
on
Recently this VI stop working from me. I checked my gmail "settings/security/lesssecureapps".  Any reason this would stop functioning on all my machines?  I set up my gmail account in outlook on one of the machines  today and outlook send email out just fine. Any help would be appreciated.
lf19902001Wahah
Member
Member
on
Did you turn it on or off? The "Access for Less Secure Apps" option should
be turned on.
Easterly81
Member
Member
on
Yes, the first thing I did was signed up for a new gmail account because the old gmail account that all the machines were using nobody knew the password. With the new Gmail account setup up with the less secure apps setting turned on still non of the machines send email.
I am using labview 8.0
lf19902001Wahah
Member
Member
on
If you have turned on the less secure apps setting, I don't know what else
you can do to solve this problem. But this is strange, the program works
well on my computer. I use LabView 2013. OS: Win7.
lf19902001Wahah
Member
Member
on
Maybe worth asking this question on Google's forum?
Easterly81
Member
Member
on
I'm using windows 2000 with labview 8, could this be the problem?  I just tried using a outlook.com email account and ran into the same issue.  I even made a simple test VI and still no luck (i tried port 25 and 587)
jeasterly
Member
Member
on
It work but not on my windows 2000 machines
