Send email using smpt client
I am trying to use the Send Email using SMTP Client example in LabVIEW.  I am trying to send through my gmail account.
The settings I have are as follows
Outgoing Mail server
smpt.gmail.com
Port
587
Username
my gmail address
Password
my password
Enable TLS
Enabled
I am getting the following error
Error 363507 occurred at LabVIEWSMTPClient.lvlib:Send.vi:2280003
Please advise
Dan Shangraw, P.E.
Message 1 of 8
(5,435 Views)
Did you google that? www.google.com/q=363507+smtp+error
It seems to be a certificate problem. The first hit isn't very useful.
The second hit, on lava might provide some answers:
https://lavag.org/topic/16601-labview-could-not-verify-the-authenticity-of-the-server/
Message 2 of 8
(5,401 Views)
The LAVA link you sent uses https web services.  I am using SMTP email.
Dan Shangraw, P.E.
Message 3 of 8
(5,380 Views)
Here's an old Gmail VI I found on the forums years ago.
As far as I know it still should work. Compare it to what you have.
=== Engineer Ambiguously ===
Message 4 of 8
(5,372 Views)
It look like I need a CA file.  I don't know how to do this right now.
https://lavag.org/topic/7755-sending-file-to-email-with-smtp/
My application is my customer wants to send an email on a failure.  We will eventually use their network.  I was hoping to try test this function of the code.  I use gmail so it is not the end use case.
I guess I will have to lean on their IT department...
Dan Shangraw, P.E.
Message 5 of 8
(5,364 Views)
It's the same error, and probably the same problem. A certificate issue, as you already found out.
Message 6 of 8
(5,356 Views)
Have you tried changing "Allow less secure apps" to ON in your Gmail account settings?  It introduces a security vulnerability, but could be a temporary workaround while you get your certificates worked out.
Message 7 of 8
(5,354 Views)
I used OpenSSL in the past to do that. Google "openssl create self signed certificate" and you'll find some tutorials.
Message 8 of 8
(5,351 Views)
