Selective Excel data using true/false case on LV
Hi Everyone!
Thank you for taking time to click on this question.
I am wondering how to graph specific rows of data from specific columns and use the true or false case to select which data in the array is displayed on the graph.
I have attached a sample excel file.
Column C is comprised of values of 0 and 1, where I only want the values from the rows where there is a value of 1 in column C.
I plan to graph Column A against Column B only with the rows where Column C has the value of 1.
Thank you so much!
(1,824 Views)
Hi LJM,
Simple steps:
  1. Read the data from your Excel file using RGT functions. (I recommend to convert the file into a CSV file, then your VI will be much simpler.)
  2. Filter your data using the 3rd column as condition: a FOR loop with a conditional output tunnel will make this very easy!
  3. Create a plot from 1st and 2nd column…
What have you tried? Where are you stuck?
(1,814 Views)
Thank you very much for the response!
I still don't fully understand the lingo as this is my first time ever programming let alone understanding what each one means. I have been able to do the very basics such as graphing and creating arrays. However, in cases like these, I cannot even begin.
I am also a visual learner and there are not many helpful specific things on youtube
The LabView community has been nothing but helpful however.
(1,756 Views)
Here is an image of what I understand but it is wrong since I cannot even run the CSV file.
(1,752 Views)
Hi LJM,
How do you "run a CSV file"? It's just text, which you can read…
(Why do you attach an image of code when you could attach the real code?)
See this:
(1,724 Views)
