Selecting which image to display
I don't know why all three displays show always the same image. Try with any three images, and you'll see that.
Message 11 of 20
(2,206 Views)
EvenDeejay,
I can't open your file - access violation.
Message 12 of 20
(2,204 Views)
Hi again,
I think I missed the functionality you were looking for. So, nevermind my VI.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 13 of 20
(2,203 Views)
What LabVIEW version are you using?
Even
Topro AS
Norway
Message 14 of 20
(2,199 Views)
I am using LabView 2011.
Message 15 of 20
(2,193 Views)
Here's for LV2010. You should be able to open it. If not, It's probably because I don't have IMAQ.
Even
Topro AS
Norway
Message 16 of 20
(2,192 Views)
Hmm. Seem's to something wrong here. Anyways, here's a picture:
Seems to be something wrong with the forum today. I can't use Opera to reply posts.
Even
Topro AS
Norway
Message 17 of 20
(2,189 Views)
Still cannot open it.
Message 18 of 20
(2,188 Views)
Accepted by bikekowal
OK, I found an error. I used the same 'Image Name' with every IMAQ... that's the way it goes when you use copy&paste... OK , now my code works great. Problem solved 🙂 Thanks for your time and help.
Message 19 of 20
(2,186 Views)
If you found the solution, could you mark this topic as closed?
Peter
Message 20 of 20
(2,174 Views)
