Selecting multiple files during run time from a list of files
Hey
I have text files in a folder and I am looking to list out all the files in the folder and then manually select a few files out of it ( while the program is running) and average the data in the selected file alone. Using list folder, I could get the file list. But since the file list is in array of string format , I can't do any selection. I also tried combo box. It can select only one file at a time. Is there any other way ?
Many Thanks
Neeraj
(3,511 Views)
Load the names as string into a listbox and configure it for multiple selections. The value will be an array of indices that you can use the get the subset of files you want.
Use ctrl-click to select individual files.
(3,476 Views)
Use a listbox (& set the selection mode), or use a file dialog set to allow multiple selection.
(3,475 Views)
Hey ,
Thanks for the reply. I loaded the string into listbox and configured it to multiple selection. But how to retrieve the value of the indices that is selected in the list box?
(3,460 Views)
Accepted by neerajp
As I said, the "value" of the listbox is an array of indices. Just autoindex it on a for loop containing an "index array" to get the elements of your array of paths.
(3,454 Views)
Hey
Thank You so much. It worked. 🙂
(3,446 Views)
