Select records in Database using SQL query between 2 dates
I have some datas saved onto an SQL database. I want to select only the records between two different dates (datetime type for the column). The records include day and hour. I want to select datas between two days.
Do you know what is the syntax of the SQL query?
Thanks a lot!
Gael
(5,366 Views)
Thanks a lot!
Gael
I guess you didn't bother to try Google first.
(5,354 Views)
 Follow this link.
Sivaraj M.S
CLA
(5,349 Views)
Though this has nothing to do with LabVIEW, your query will look like the following:
select Date, TotalAllowance from Calculation where EmployeeId = 1
             and Date between '2011/02/25' and '2011/02/27'
or can use
             and Date >= '2011/02/25' and Date <= '2011/02/27'
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(5,327 Views)
