Array with increment
question is:
Have a while loop iterate over elements in “Loop 2 In” and check if the element is equal to 0 if it is end the loop and output the element #(loop iteration) where the first 0 occurs. I.E. input [44,2,0,12] should output 2 because the 0 element is 44, the 1st element is 2 and the 2nd element is 0. If there is no 0’s in your loop it will take the first blank element as a zero and claim that to be the first 0 in the array.
and all i really have is,
Screen Shot 2017-10-22 at 4.22.13 PM.pngPlease help what to do..I am stuck on this question for awhile!!
(5,552 Views)
You could use Search 1-D array for the zero value.
(5,543 Views)
In the real world, we would just use Search 1D Array.  In situations where I am looking for a specific value in an array of clusters (looking for the element with a certain value in the cluster), then I have used a FOR loop with the Loop Terminator turned on.  Just autoindex on the array and do the comparison inside of the loop.  If your comparison is TRUE, the loop stops.  I also tend to output the cluster (tunnel set to Last Value) so then I have the needed value.  In your case, you use the i terminal instead.
(5,530 Views)
It is the solution.
Ing. Ovidio Torres (El Salvador).
(5,517 Views)
As its just an a Numeric array without decimal points, Use search 1D Array where you will get the output as First found index and if its not you will get the output as -1
(5,473 Views)
Yet another homework question...
Kudos are welcome...
(5,455 Views)
As a side note: avoid using comparisons with DBL numbers. You may not get what you expect.
0.0000000000000001 does NOT equal 0
(5,427 Views)
