Select file from list box and read data from file
I can list files from folder in listbox
1- I want list just .txt files from folder
2- How can i read data from selected file (.txt)?
(5,000 Views)
Accepted by topic author keremgeliz
I think this is what you want... enter a pattern into your List Folders vi (e.g. *.txt) and then just use Read Text File.vi using the selected item from the list box (double click event or value change) and use the starting path for the List Folders vi.  I included a rough snippet for your viewing enjoyment.
(4,990 Views)
Hi Inerta.
Can you add vi for lv2012 my internet explorer have problems.
Thank you
(4,979 Views)
@keremgeliz wrote:
Hi Inerta.
Thank you
Why don't you try to build it up yourself?  It is a simple enough of a diagram.
(4,977 Views)
You right again crossrulz 🙂
(4,961 Views)
