Select array elements dynamically
Hello ...
I am trying to write a program where one can select the array elements dynamically from the front panel when the VI is in run mode.
So far, IC_OpenDevice.vi gives me the various Video formats [It is a 1D array], right now I assume the last but one among this array as an example. But, I would like to design the program in such a way that the user can select any Video Format from the front panel. How do I achieve that ??
Block Diagram :
Front Panel:
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(5,065 Views)
Use a numeric control to pick the index you want.  I'm not sure what else you are looking for.
(5,048 Views)
Place the array into the "strings []" properties of e.g. a ring, then use the ring output to index into the array of video formats.  Or you could use a listbox.
(Also note that if your stop and grab buttons are latch action, their terminal should be placed into their respective event cases so they reset properly.)
(5,045 Views)
I tried following the same method on my program.
However, I get the Error -2147352567 ... Below is the changes I made to my program ...
Abhilash S Nair
LabView Gear:
(5,006 Views)
Accepted by abikutn
Why didn't you put the update to the video format in the event structure?  You could use the "Video Format 2":Value Change event.  Then it is all in one easy loop.
And you don't need that wait in your top loop since teh event structure will take care of your timing.
(5,002 Views)
Thanks for the idea. I tried putting the event change in the while loop and let the even handler control the video format input. But, when I run the VI , why do I get this error ?
Abhilash S Nair
LabView Gear:
(4,986 Views)
Thanks !
Figured out ... This event strucrue is really helpful stuff ... Smiley Happy
Abhilash S Nair
LabView Gear:
(4,984 Views)
