Searching from excel file
Hi Sam,
still filtering your 2D array of strings?
Your VI works as described by Christian - when I replace your ReadSpreadsheetFile function by an array constant with some default data, similar to what can be seen in Christians image.
So the question is:
- Can you supply some typical data?
- Can you tell us the criteria to filter that data?
- Can you show us the expected output for the data and the criteria?
Message 31 of 96
(2,127 Views)
@GerdW wrote:
Hi Sam,
So the question is:
I already uploaded my VI file,
I just try to get a two selected column from the .xls file and then from these two column i try to get some selected rows. for example
if (selected column found in xls ) then
     store into array
     if (values found in these selected column rows) then
           store these rows into array
end
A    B    C    D    E
1    2     3    4     4
6    4     7    2     9
2    4     6    3     9
2    5    7    8     9
first let suppose A and D column selected then these two column store in array and then search 9 number in these two column if 9 number is present in both column then those rows store in new array.
Message 32 of 96
(2,124 Views)
Hi sam,
then why don't you use Christians solution to your problem?
Do you even try to learn from all our suggestions?
Message 33 of 96
(2,116 Views)
Hi @GerdW thanks man
Message 34 of 96
(2,105 Views)
hello everyone, i need little bit more help, this is my current code in which i get xls data into array and search selective columns but now i want to search from some exact data like data between 15 to 18 numbers of selective columns.
For example,
A B C D are xls file columns and in which i select B and D column, now i want to search data from these columns where value is between 15 to 18. Here is my current working code, it run but didn't give me exact results. Please find an attachment and give me some suggestions. Thanks
Message 35 of 96
(2,097 Views)
Hi sam,
there is an "In range and coerce" function to test for ranges…
Message 36 of 96
(2,092 Views)
Hi sam,
Now you should have learned how to filter your arrays.
But you still aren't able to reproduce the very same algorithm to filter your arrays again? All that has changed is the filter condition!
Instead of "keep data IF element == 'A'" you have to implement "keep data IF element is in range"…
Just to give an idea:
Message 37 of 96
(2,088 Views)
@GerdW  작성:
Hi sam,
Hi, Thanks GerdW.
I need one more suggestion in one problem,
for example, there is a file in which there are some data (data in integer), so i need to find the data which is continuously higher (like 14 15 16 17 15 43 5 76 5) (Not like this 14 11 4 2 4 1 6 6 8 9 65 34 12 67 4 6). And it is not liner searching because liner searching is slow in speed.
Message 38 of 96
(2,078 Views)
Hi sam,
Please define "continuously higher"! Are you talking about monotonously rising numbers?
Your example of "14 15 16 17 15 43 5 76 5" doesn't fit into this requirement, so please be more specific and accurate!
What is "liner search"? Are you talking about linear search?
And why do you think it is slow (for your task)? And why do you think you need it at all to fulfill your request?
Message 39 of 96
(2,068 Views)
@GerdW wrote:
Hi sam,
Hi GerdW, yes monotonously rising number like (15 16 17 23 24 26 26 27),
And 2nd yes Linear searching, actually if thousands of rows find then one by one search take time. I need to search data from file for verification.
Message 40 of 96
(2,061 Views)
