Search for string value Without converting to array
How do I go through a string to search for a value (Format: Variable = value\tVariable2 = value2), Without converting to array.
Message 1 of 10
(4,848 Views)
Hi Rafael,
use SearchString function to look for your "variable", then parse the value after the "="...
Message 2 of 10
(4,847 Views)
I need to limit the search to \ t (tab), how do I?
Message 3 of 10
(4,835 Views)
Accepted by rafael.assis16
You could also use Match Regular Expression
Message 4 of 10
(4,809 Views)
Hi Rafael,
Why? (According to your other thread you should search the whole string…)
To answer your question:
1. Search for tab and keep the substring before the tab
2. Search your "variable" in the substring and get the value after the following "=".
Message 5 of 10
(4,808 Views)
Excellent, could you give me a website to better understand Match Regular Expression?
Message 6 of 10
(4,775 Views)
I need two types of search, one going through the arrays and another the string, so I'll have two options if necessary.
Message 7 of 10
(4,774 Views)
Just use the Help built into LabVIEW.  You can access the proper page via the Context Help or right-click on a Match Regular Expression and choose "Help".
Message 8 of 10
(4,765 Views)
Try https://regexr.com/
Message 9 of 10
(4,755 Views)
Tks.
Message 10 of 10
(4,753 Views)
