Search for a subarray in array
Hi!
Is there a VI or a simple way to search for a subarray in array and to get the index of the subarray? The same thing does DTbl Search for Digital Pattern.vi with digital data and Search 1D Array.vi searches for just one element in the array.
Thank you!
(6,205 Views)
Hi salomiva,
you could use Search1DArray. Check for the first element, when found you just check the following elements...
(6,196 Views)
Depending on your needs, something like this might suffice.
Using the Search 1D Array function will find the locations of the FIRST occurrence of every element in the subarray. (As demonstrated with the number "1" in the example below)
If the element cannot be found, it returns a -1. (As demonstrated with the number "9" in the example below).
You can check this each iteration for error checking.  (Or search the output array for -1 using the same Search 1D Array function).
**Note:  Also remember that arrays are 0 indexed! 😄
If someone helped you out, please select their post as the solution and/or give them Kudos!
(6,186 Views)
Accepted by topic author salomiva
Playing around with Gerd's idea of using the search 1D Array, I came up with this.
(6,164 Views)
I tried to play around Gerd’s idea as well but your solution looks much better! Thanx!
(6,104 Views)
