Running Labview VI in Sig Express, problem seeing inputs other than waveform
I've posted this in the Signal Express Forum, but haven't gotten a response in about a week, so I'm cross-posting here.
I'm trying to run a Labview VI inside SE. I've connected 3 inputs from the VI to the connector pane. Two are type waveform, one is type double.
When trying to connect to the VI input of type double in SE, I only see waveforms as the possible list of connection signals. The signal of type double which is generated by SE, which I wish to connect to the Labview VI, does not appear in the list as a possible signal.
Has anyone run into this problem, and knows a solution? Thanks.
Message 1 of 1
(2,302 Views)
