Search for a pattern in array
Hi Tom,
default editing mode -> Binary, 4 digits, with leading zeros
advanced editing mode: %04b
Message 21 of 40
(1,034 Views)
Hi Gerd,
I've made several exercises with this code.
It's a great simplifying of decoding.
In next step I'm trying to "cut-out " from Input array portions of 18 messages if  6 first bits are equal to 1.
I'm struggling with two issues:
1. Compound Arithmetic returns TRUE only with first iteration of internal LOOP.
 Even if all six inputs in following iteration provides TRUE and Boolean Compound Arithmetic (AND) shall returns TRUE  it returns  FALSE
2. Case structure returns 2 times "Matched Found Array" with detection.
Is there more simple method to receive 2-D subarrays which starts with 111111 and contain 18 following rows?
Best regards
Tom
Message 22 of 40
(1,001 Views)
Hi Tom,
mind to downconvert for LV2019?
On your image:
  • Comparing a boolean with TRUE is Rube-Goldberg!
  • All those "+1" are Rube-Goldberg!
  • When the inner loop iterates FOREVER then the outer loop is senseless...
  • Why don't you index a row from your 2D array and compare with a constant to detect your "TTTTTT" condition?
  • This shift register of the inner loop seems senseless, too.
Message 23 of 40
(997 Views)
Hi Gerd,
I think that on code below all "Rube-Goldberg" machines are eliminated
After first test, it looks that it works correctly.
Let me know Your comments.
P.S In next session, I will start the battle with decoding data from captured messages
Best regards
Tom
Message 24 of 40
(986 Views)
Hi Tom,
Well, I see several possible improvements - but you didn't attach code converted for LV2019…
Message 25 of 40
(983 Views)
Hi Gerd,
Should I issue request for downconvert in separated forum on NI Community?
I don't see at first look this kind of option in my Labview.
Tom
Message 26 of 40
(979 Views)
Hi Tom,
Did I mention "File->Save for previous" before? (Ok, apparently not in this thread…)
Message 27 of 40
(977 Views)
Hi Gerd,
Attached is VI downconverted to the LV 2019.
If You will detect any potential optimization opportunities, let me know please.
Thank You
Best regards
Tom
Message 28 of 40
(970 Views)
Hi Tom,
Nope, you still attached the VI saved in LV2020.
Fortunately I'm on a computer with LV2021 now…
See this:
As you get only 2 bits from your numeric data the "appended array" contains only 2 columns (after transposing)!
Message 29 of 40
(956 Views)
Hi Gerd,
This is also very good solution.
There should be Decrement instead of increment otherwise we lost first two rows ( there is TTTT instead of TTTTTT)
My improvements are:
- eliminate Loop For - only one loop
- elimination array transposition function but adding array subset + index array. This will give me that all subsets are separated to the Matched Found Array.
Attached VI
best regards
Tom
Message 30 of 40
(942 Views)
