Search and replace with comma
Hello All,
I want some help. Please help me.
I have comma delimited Data. When I’m converting Sting to Array, If two commas exists in between then its displaying “Zero” (because its array propriety ). Instead of that I want to display “NaN” .
Please give me any idea to replace comma to NaN. I tried with Search and Replace but it’s not giving as I expected.
Munna
Message 1 of 10
(4,850 Views)
Accepted by Munna232
Hi Munna,
replace all ",," appearances by ",NaN," before converting from string to array:
Message 2 of 10
(4,841 Views)
Thanks for your reply.
Please check this snippet. Here, at end of the string, I have two commas so we will get 10,NaN,20,……. 12,NaN. But I don’t know why zero is adding to array (last element) If end of the String having only commas.
Munna
Message 3 of 10
(4,823 Views)
Hi Munna,
you really need to explain your requirements better in the first step…
Those two last comma are converted to ",NaN,". SpreadsheetstringToArray converts this to ",NaN,Zero" because you have set the comma as separator char and this function expects a valid entry after the last comma. If you don't like this behaviour you need to delete the last comma, when it is the last char of the string!
Message 4 of 10
(4,821 Views)
Hello GerdW,
Thanks for your reply & Sorry for the inconvenience.
As per my data file, If end of the String comma exists I need to display “NaN”. (it means 12, NaN, NaN)
Munna
Message 5 of 10
(4,813 Views)
Hi Munna,
again a different requirement!
Replace a trailing comma with "NaN" and you're done…
Why do you add an additional trailing comma to your string? This will be no help at all!
Message 6 of 10
(4,810 Views)
Hi GerdW,
I want to display NaN if Data is not present after the Comma.
Example:
  1. 10,,12,,,30,, ----- > 10 NaN 12 NaN NaN 30 NaN NaN
  2. 10,,12,,,30 ----- > 10 NaN 12 NaN NaN 30
Munna
Message 7 of 10
(4,804 Views)
Hi Munna,
as said before: replace trailing comma by ",NaN":
Message 8 of 10
(4,797 Views)
Hello GerdW,
Thanks you so much for your reply.
I thought, instead of replacing trailing comma by NaN adding comma before string is more better (because to many string manipulations) But, it’s taking more execution time.
Munna
Message 9 of 10
(4,782 Views)
Hi Munna,
When you really want to compare both approaches you should not run them in parallel. That's not the recommended way to measure execution time…
Message 10 of 10
(4,772 Views)
