Search and Replace elements in an array
Hello, I am new to LabView and was to create some basic VI's . I was able to make a search and replace Program but now I want a counter to indicate how many elements were found and replaced. How do I do that?
Thank You
(3,152 Views)
You need while loop and shift registers.
In your code for loop works as many times as array length, but you need stop if already no elements.
Also your program never replaces first element
(3,131 Views)
Not Maintained Search Order anyways it will Once replaced with new number it wont alter the array values, so search can be started from zero it wont create difference.
(3,122 Views)
Those controls should be outside the loop.
And of course passing the start index in a shift register will make a difference! Starting over form 0 will cost CPU cycles, which is not necessary. This will make more difference as those arrays grow in size.
(3,115 Views)
Exactly! this why I use second shift-register
(3,109 Views)
Thanks Points Taken, Suggested points are taken into consideration.
(3,102 Views)
