09-12-2023 01:57 PM
Every time I go to use the search function in one of my projects, the entire LabVIEW program crashes. I use LabVIEW 21.
I get this error:
09-14-2023 07:49 AM
which one? ctrl+F ?
09-14-2023 07:51 AM
Yes, ctrl +F, then I type in the term i want to search for, hit enter, and then LabVIEW crashes completely
09-14-2023 09:08 AM
does it have an effect when you uncheck the following items via tools>options>search ?
09-14-2023 09:11 AM
No luck with that either.
09-14-2023 11:38 AM
This sounds like a problem Darren described in a presentation he did.
Link to video of the presentation, time stamped to where he talks about it:
https://youtu.be/HKcEYkksW_o?t=1340
Do you by chance have an actor framework PPL loaded in your project like the customer in the video did? If you don't have that, then maybe something else you have loaded has a similar issue.
If you do this with no project open (just one empty VI) does it still crash?
09-14-2023 12:51 PM
It is just one project that has this issue- all of my other projects I can use ctrl + F with no problems.
09-14-2023 01:27 PM
Sorry, I interpreted "in one of my projects" in the original post to mean "in any one of my projects" instead of "in only one of my projects".
The general failure still sounds like what Darren describes in his video. Do you have a PPL loaded in that project somewhere, either directly or as a dependency of something? If so, could you add the PPL or PPLs from that nonworking project to another one that does work and see if the problem follows it?
09-15-2023 02:51 AM
this must be some kind of cache-issue...
does this ctrl+f issue also occur when you make a copy of the "affected" project and use ctrl+f in the copied project?
guesses:
I would try to force a recompile, clear the object cache, ...
09-15-2023 07:35 AM
Yes, the copied project has the same issue.
