Search Array of string
Hi ,
i have an array of string  that i want to extract how many times each element appear.
thank you.
(2,989 Views)
@Emna20 wrote:
Hi ,
thank you.
Is the element one character or a sequence?
If it's one element, convert to byte array, and use Equal? on a byte element. Then convert the Boolean array to 0-1, and add the elements.
If it's a longer string, use a match pattern, and put it in a while loop. Put the start index in a shift register. Stop looping if the result is -1. "i" is the number of elements found.
(2,975 Views)
Take a look here for a similar question.
(2,949 Views)
With LabVIEW 2019, I would do a similar structure except using Maps.  You should see a little more performance and the structure is easier to understand.
(2,917 Views)
