Scrollbar appearance
I would like to change the appearance (color of the parts) of the scrollbar in Listbox. How can I do that?
Andrej
Message 1 of 9
(4,233 Views)
Right click the listbox.  Advanced  >>  Customize.
You can acually use the color paintbrush directly on some parts of the scrollbar if you want to.
Message 2 of 9
(4,229 Views)
I've tried, but I can only change the color of entire scrollbar.
Could you be more specific on how to color separate parts of the scrollbar?
Andrej
Message 3 of 9
(4,225 Views)
I think you can't separate the colors of the different parts of the scrollbar (e.g. the background, slider, ...) If you press the spacebar with the coloring tool you can change the color of the triangle at the top and bottom of the scroll bar.
Ben64
Message 4 of 9
(4,222 Views)
Yes. But I must also change the color of the different parts, otherwise my GUI will be ugly.
I will try to create an XControl that will use customized vertical slide instead of the scrollbar.
Message 5 of 9
(4,218 Views)
As Ben said, I believe there are only a couple of things you can change..
I find it funny that you say you need to modify it even more than you can to keep it from looking ugly.  In my experience, the ugliest front panels are those created by people who tried to do any kind of color modification to there controls.
Message 6 of 9
(4,214 Views)
My GUI was designed by a professional designer and in accordance to that I must also change the appearance of the scrollbar 🙂
I've already customized other controls.
Message 7 of 9
(4,210 Views)
I had to make my own. It take time but it is worth it. Now I can change to what ever I want. See below:
Tim
GHSP
Message 8 of 9
(4,206 Views)
@andrej wrote:
[...] otherwise my GUI will be ugly.
Be careful what you ask for.  Beauty is in the eye of the beholder.
Jim
Message 9 of 9
(4,204 Views)
