Scrollbar Customization in LabVIEW
I am trying to increase the scrollbar width of the array with customization for a touchscreen application. The changes in scrollbar width are not retained when closing LabVIEW and opening it again. I tried making it strict typedef and still, the changes are not retained. Smiley Frustrated I also tried with other types of controls like modern and classic. I have attached the previews for reference.
Anyone have any ideas how this can be done?
Thanks!! Smiley Happy
(6,193 Views)
It appears to be a LabVIEW bug.  I can't think of an easy solution; a hard solution would be to create an XControl.
(6,160 Views)
It doesn't work with making it a Custom Control? If so, I guess you'll have to drop a free scrollbar from the numeric panel and use that ones events to change your array.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(6,123 Views)
Yes I too was frustrated by standard width scrollbars on touch screens and tried a few things.  Here is a XControl I made which has the ability set it to a larger width and can fit to a pane.  Open the Demo Large Scroll to see it in action.
(6,101 Views)
Got a solution here
Adding following keys in LV ini file enables resizing scrollbars.
AutosizeScrollbar=False
autoResizeScrollbars=false
(6,079 Views)
I never tested those INI keys but I thought that those didn't work consistently.  They would work on your system but when the EXE is built and put on a computer without those INI keys it would revert back, or other developers opening the VIs would see the normal scrollbars, save the VI and then when it was reopened it wouldn't retain the size.
(6,068 Views)
I guess your installer needs to change the LV.ini then. 😉
/Y
Qestit Systems
(5,997 Views)
