Scripting: Recognise type of function in BD
My script should control if the wire is connected to particular function. The script works easy but... crazy.
When types of Owners (nodes connected to the wire) are controlled, the most specific obtainable type is "Function". But which Function is it? (I need Close Reference but the same can be questioned about any other function). The only way I found is comparing icons as shown in the  snippet. Isn't it little crazy?
There should be a better way but which?
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
(2,841 Views)
Accepted by topic author _Y_
Read the "Style" property of the Function class. It will tell you the non-localized English name of the function... "Add", "Match Pattern", etc.
(2,821 Views)
@Darren wrote:
Read the "Style"...
Yes, indeed, thank you. I would never guess...
Well, my English is not perfect 😉
(2,807 Views)
