Scripting: Recognise get terminal pattern of VIRefNum
The terminal solution only works if the control has a terminal, which the control on the panel of a .ctl will not. Try using the Value property instead of the Terminal.Data Type property.
Message 11 of 19
(1,807 Views)
Yes, Darren, reading Value property does not return any error. However, I cannot find how to use obtained value Variant.
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
Message 12 of 19
(1,779 Views)
I don't understand your question.
Message 13 of 19
(1,771 Views)
I can read Value but cannot use it for obtaining any information about terminals.
This is illustration of my attempts; both branches launch errors in last steps:
Message 14 of 19
(1,764 Views)
Look at my previous screenshot...you can get an array of the terminal data types from the Get VI Information VI.
Message 15 of 19
(1,760 Views)
Sorry, I tested it first and forgot to present in the message. It returns number of terminals but not their types:
Message 16 of 19
(1,756 Views)
Seems I have solved the problem just now. But my hack is really ugly.
The script creates dummy VI, adds a Call By Reference node in its BD, connects the node to the type-defined input, and reads terminals of the Call By Reference node:
It works... but I'm not happy with such ugly things. Probably there is a better way.
Message 17 of 19
(1,752 Views)
Accepted by topic author _Y_
The VI you're using in the For Loop should be Get Type Information.vi, not Get VI Information.vi. When you use the proper VI in the For Loop, you'll get the type info you're looking for.
Message 18 of 19
(1,751 Views)
Yes, Darren, this was my mistake. Sorry. I placed wrong VI in BD and considered solution as non-functional.
Message 19 of 19
(1,747 Views)
