Script Error when click on Find Example in LabVIEW Help
Bruno,
     LabVIEW underwent a significant change in 2017 (and LabVIEW 2017) with the introduction of the NI Package Manager, and the new LabVIEW NXG "Next Generation" release.  There have been several discussions of problems involving installations of LabVIEW versions that "cross" the 2016/2017 boundary.  Furthermore, I recently learned that NI seems to consider 5 years the largest "gap" in LabVIEW Versions that one should consider using.  That is, if you are using LabVIEW 2011, you "should not" install any LabVIEW version newer than 2011+5 or LabVIEW 2016.
Unfortunately, once you install LabVIEW 2017 or 2018, selective removal of just those versions will probably prove difficult.  The safest way forward involves a "fresh" install, meaning starting with a system without LabVIEW and installing the Versions you want to use, oldest first (as LabVIEW prevents installing an older version "on top of" a newer one).
Message 41 of 69
(3,375 Views)
@Bob_Schor wrote:
Bruno,
Isn't that the same gap used for driver compatibility?  Maybe that's the reason?
Bill
CLD
(Mid-Level minion.)
Message 42 of 69
(3,373 Views)
I´ve actually got two different computers / LabView / Windows versions which both experience the same LabView Help Script Error after Windows Update.
LabView 2011 Home on Windows 7 (work license)
LabView 2014 Home on Windows 10 (student edition for experimenting at home)
Message 43 of 69
(3,362 Views)
I have 2017 and 2018 on a Win 7 x64 box that has the script issue.  I also have 2011 installed on a win 7 x64 and win 7 x32 machines with the issue.
But I did find a XP Pro virtual machine running 2012 that works fine..He He
Message 44 of 69
(3,306 Views)
Probably because MS is no longer deploying updates for WinXP.  But still are for Win 7.  The update that breaks the help dialog is a relatively new update.
I believe your observations help confirm that.
Message 45 of 69
(3,302 Views)
That is why I added "He He" at the end.  I guess I should have just used Smiley Wink
I also wanted to subscribe for when there is a fix or more information.
Message 46 of 69
(3,297 Views)
As I don't see this posted here, I wanted to point out Microsoft released updates recently.  The following list of fixes should correct the scripting behavior we're seeing.
Windows 10, version 1703: KB4480959
Windows 10, version 1709: KB4480967
Windows 10, version 1803: KB4480976
For Windows 7 there is an “Preview of Monthly Rollup” KB4480955 from January 17, 2019
Message 47 of 69
(3,223 Views)
@BoKnows Thanks for posting!  I'm the original poster - I just ran MS updates and it appears to have fixed the problem! I am running Windows 10 and LabVIEW 2017 17.0f2 (32 bit)
Message 48 of 69
(3,217 Views)
I am running Win 10 version 1809 and it is still broken.  I tried 2017 and 2018.
Message 49 of 69
(3,191 Views)
Sorry to hear that. I unmarked your post as the solution.
More details on my install:
Windows 10 Pro for Workstations
Version 1803
Build 17134.556
Listing the KBs for to allow searches: KB4480976, KB4100347, KB4477137, KB4465663, KB4456655, KB4230204, KB4343669
Message 50 of 69
(3,128 Views)
