Script Class's "Default Palette"?
I'm looking to modify the Default Palette of a class, through scripting:
But I'm unable to find a property/method available on the class to do this. Anyone know if it's possible to script this? Thanks!
(2,187 Views)
I can't even figure out how to change it manually.
(2,153 Views)
Accepted by topic author _carl
This works sometimes but sometimes gives a "library locked" error and I'm not sure what is locking it.
I assume that it will only work if the menu file is a class member already...
(2,147 Views)
Yes this is how I do it with making VIPM packages.  During the Pre Build process I will add the most root MNU that I want to the root of the class, then run that VI server command to set the class to have that MNU as the default for the class.
(2,129 Views)
You're likely getting the library locked error because the class is being opened in multiple application instances. Make sure when you call the Library.Open method you are wiring in the App Instance to that method for My Computer, or whatever app instance owns the class. Or that the VI you're running to modify the class is under the same target in the project as the class (and not, for example, in the Main App Instance outside of the project).
(2,117 Views)
Ah, nice!  Also...this looks like a much cleaner/safer option than modifying the XML directly, which is something I've resorted to (with varying success) in the past...
(2,089 Views)
