Screen position of control in nested subpanels
@Yamaeda wrote:
The Panel.bounds gives screen coordinates, so that + control position should give screen position regardless of subpanel level.
I think that this also needs correction for the pane origin?
I'm not sure if it will work with more then 1 pane.
This is all way too difficult...
Message 11 of 12
(328 Views)
Quick test showed that to be the case, yes. Moving the sub panel and saving it yielded the same result with the code above ...
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 12
(314 Views)
