Screen Dump doesn't always work
Hi Cory,
So, it's like my app doesn't know that location exists until I go there in explorer and them come back to my app.  Why is that?
Did you read my answer here? (Talk with your IT department admin…)
Now, what the heck do I do with the snippet?
Use it to replace your overly complex own version of creating a file path…
Message 11 of 18
(1,739 Views)
My IT folks will not want to hear from me.  Is there anyway to perform a 'handshake' from within Labview?
Are you saying I just use the snippet pasted into my vi as a guide to replace what I have?  I was under the assumption it would become the new code in my vi.
Ron
Message 12 of 18
(1,722 Views)
Hi Cory,
Why not?
You may try to call SysExec with "cmd /c dir Y:\JobNumber" as argument. Let Windows initialize the network drive connection…
The snippet is a replacement for your big ConcatString mess to generate a file path…
(You should be able to recognize what my code snippet does and to understand its operation by now.)
Message 13 of 18
(1,720 Views)
Ron,
What happens when you try to build the file path using the method put forth by GerdW?
PahlM
Message 14 of 18
(1,709 Views)
Willing to try SysExec, but don't know what it looks like in LabVIEW.  Nothing comes up in Help for SysExec.  Excuse my ignorance for not knowing this vi.  Never used it before.
Message 15 of 18
(1,691 Views)
Hi Cory,
The function is called "System Exec". It is the first entry (for my LV2017) when you type "sys" in QuickDrop…
Message 16 of 18
(1,690 Views)
Found the System Executable command.  Will try it.  Thanks.
Message 17 of 18
(1,684 Views)
Works!  Thank you!  Now on to my saving data loop.  I decided to go with a log timer that approximates the rpm curve on a motor run down.  I really don't have a limit on the number of points saved, since they are only points, not large data arrays.
Thank you for all of your help!
Message 18 of 18
(1,681 Views)
