Showing results forĀ
Search instead forĀ
Did you mean:Ā
Scope SFP application
Hello
Is the Scope Soft Front Panel application available?
If one had the free time this application could be created in it's entirety, but I do not have such available time :).  I think that this would be a strong starting point that would provide any user to use the parts that are provided and build it into something that they need faster then starting from scratch.
(3,716 Views)
If you're talking about NI-SCOPE, then I believe the answer is no, and further, that it isn't implemented in LabVIEW code at all.
It is possible to use the scope api to build your own code though.
GCentral
(3,682 Views)
I found the references I read here and here.
GCentral
(3,659 Views)
Hi Nickede,
The Scope Soft Front panel application will be installed with NI-SCOPE 17.1:
https://www.ni.com/en/support/downloads/drivers/download.ni-scope.html#307052
NI-SCOPE will also install NI-DAQ and it should run as a stand-alone application.  If you are planning to also have an installation instance of LabVIEW, you should make sure that is installed first (same is true for Visual Studio).
Adam
(3,639 Views)
