Scan from string does not find number
For the original poster, you could expand the regex to include all floting point numbers by searching for regex [+-]?\d+[.]?\d*+(?:[eE][+-]?\d+)
This regex can be simplified to [Ee+-\d.]+
The original RegEx of Stephen's is actually fairly common, and is meant to *only* match floating point numbers with or without the exponential notation.  The simplified version will match a lot of patterns that are not properly formed floating point numbers (E+e12+E-2ee).   Depends on how well you know the form of the input, and how much you trust it.
Message 11 of 14
(1,361 Views)
I agree, I assume the  numbers were well formed.
Ben64
Message 12 of 14
(1,358 Views)
I took a closer look at this regex [+-]?\d+[.]?\d*+(?:[eE][+-]?\d+)
Is there a purpose to the + between \d* and the non-capturing group? I think the non-cpaturing group should be optional if we want to match a number that doesn't have an exponent.
Ben64
Message 13 of 14
(1,353 Views)
In cleaning up the quote the final ? was chopped off of the regex so the non-capture group is optional.  I agree, no need for a greedy quantifier beforehand, no harm though.
Message 14 of 14
(1,348 Views)
