Scan from string does not find number
I ran into the following problem: I have a string returned from an instrument through the serial interface. I would like to extract the numerical value from the string (double precision format). If I use the scan from string function, it does not find the numerical value. Similarly, if I use the Match Pattern function and go looking for the character "[", it does not find it returning offset past match of -1. What is going on?
Note that I cannot expect that the instrument always returns 9 characters before the start of the number.
Thanks for your help.
Peter
(using LabVIEW 8.5 on a WinXP machine)
Message 1 of 14
(10,025 Views)
Scan from string assumes what you scanning for starts at the initial scan location. And since your string doesn't start with a number (or white space followed by a number) it doesn't find anything. The '[' character has special meaning for the match function so you have to escape it (use '\['). If you escape the '[' character and feed the offset past match into the initial scan location, then the scan from string will read the number.
Message 2 of 14
(10,021 Views)
A Regular Expression will find your number.
-? will look for an optional minus sign
\d* looks for zero or more digits
\.? looks for an optional decimal point (the \ escapes the special 'dot' character)
\d+ gets any digits past the decimal point
Jim
Message 3 of 14
(9,995 Views)
I'd sure appreciate if someone would tell me why \d* doesn't work where \d+ does.
Jim
Message 4 of 14
(9,992 Views)
Interesting that one Jim,
I think it must be that everything in your regex is optional if you use \d* in both places.
If we add something that is fixed, like changing the \.? to \. it will match the .
So I suspect that we just must have something concrete in the regex for it to work at all
With a numeric, that is no problem anyway as we would always have a digit somewhere.
In your example I guess it doesnt matter which \d is * and which is +
For the original poster, you could expand the regex to include all floting point numbers by searching for regex [+-]?\d+[.]?\d*+(?:[eE][+-]?\d+)?
Steve
Stephen C
Applications Engineer
Message 5 of 14
(9,988 Views)
Accepted by topic author pbuerki
Try this:
Message 6 of 14
(9,972 Views)
I tried to drag-n-drop it onto a BD.  Kudos, anyway.  🙂
Jim
Message 7 of 14
(9,956 Views)
Alright, here's the snippet
Message 8 of 14
(9,945 Views)
Thank you all for offering several different solutions to my issue. All of them work fine. Thanks again.
Message 9 of 14
(9,901 Views)
Steve
This regex can be simplified to [Ee+-\d.]+
Ben64
Message 10 of 14
(9,873 Views)
