Scan from string and extract string between delimiter
Basic questions.  Is it possible with the scan from string regular expression to extract the string that are within the specified delimiters.  Here is an example:
\\Name of folder 1\Name of folder 2\Name of folder 3\File Name
Can the scan from string output the following by specifying the right regular expression:
Name of folder 1
Name of folder 2
Name of folder 3
File Name
I have tried \\\\%s\\%s\\%s\\%s but the %s stops at the first white space.
Michel
(3,902 Views)
Why wouldn't you just use the Path to Array of Strings function in the File I/O palette?
(3,892 Views)
Accepted by Michel_Gauvin
RavensFan suggested the appropriate function for your requirement, however you can also use an alternative, which is 'Spreadsheet String To Array'.
Strings from path
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,880 Views)
There are days like this, I guess..... 😞
(3,861 Views)
