Scan String Token Problem with leading Tokens
@QRP wrote:
I think for some reason all of this stuff is setup for ending delimitors even the spread sheet to string function. There has to be a way for Labview to be able to handle in coming serial traffic with leading tokens. I sure miss my C programming language, it's so simple that way 😃
As far as I know, C works the same way.  You could probably setup a loop that looks for 2 * and then grab the data between them.  But that's more trouble than its worth when all you need to do is throw away the first element of the array.
Message 11 of 14
(997 Views)
@QRP wrote:
Jeff you are the master my friend. Your last example worked wonderful. Thank you so much!
My name is not Jeff...
Message 12 of 14
(995 Views)
Sorry crossrulz, your example works great. Thanks again.
Message 13 of 14
(990 Views)
@QRP wrote:
Jeff, I really like your approach, but every time I run the example it returns the data starting in array offset 1 and not 0, why would that be?
With *xx*xx*xx, Because there was no string before the first delimiter so an empty string is generated.  If all tokens are at the end of the string xx*xx*xx* the last value would be empty. with xx*xx*xx only three elements are generated
"Should be" isn't "Is" -Jay
Message 14 of 14
(984 Views)
