Scam string and replace value
Dear all,
I have one string that is read from Excel like this: "-90 db, 10 us, 100 Hz" that is used in some tests. I can't change this format.
The numbers can change and the code should be generic for any number.
For an expecific case I would like to replace the second number (duration in us) for a decimal that I will calculate.
This means that I only have to find the second "%d" (decimal number in the string) and replace for another number.
Is there any VI for that? I have been trying with some of them inside loops with no sucess... Please I would like some tips.
Thank you,
Thais Marques
Message 1 of 15
(5,181 Views)
One of the many possible ways:
Hope this helps.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 15
(5,163 Views)
Hi Thais
You can do something like this
1) Split string up in 3 bits by using the ,
2) Pull out what is between the 0 spaces og the middle string
3) Change this to a floating points tring with X number of precision
4) Build the string back up.
I have also attached the example in LabVIEW 2012 format.
Best Regards
Anders Rohde
National Instruments Denmark
Message 3 of 15
(5,158 Views)
Ugh, a pet peeve of mine.  You capitalize the "H" in "Hz" - why not the "B" in "dB?"  After all, they both refer to proper names.  😉
Bill
CLD
(Mid-Level minion.)
Message 4 of 15
(5,153 Views)
Unit capitalization is one of my peeves as well.  There's nothing quite like reading a test procedure and it says "Pulse the input for 500MS".  500 Megaseconds!????  Oh, you mean 500 milliseconds.  That's 500ms (or if you really want to capiltalize the seconds, 500mS).
Message 5 of 15
(5,143 Views)
dear gosh people.
i just typed myself this. that is a simplification of my string (because the whole problem is much bigger!);
What is the problem of one letter not capitalized?!!!!!!!!!!!!!!!!!!!! that is not the point of my question.
that is not a document, is not a report............ just a post!!
anyway thanks for who helped me really 🙂
Message 6 of 15
(5,136 Views)
Use the 'Spreadsheet String To Array' then 'Fract/Exp String To Number' to give you an array of floats from the Excel spread sheet.
You can then pick and choose which item you need or skip over or replace.
I used a float because db and hz could be given as floating point
Omar
Message 7 of 15
(5,114 Views)
Hi Omar,
is there a reason to use two functions when one will do the same?
Message 8 of 15
(5,109 Views)
No. I first though the OP needed to replace a string keeping the output a string, So I started down that path keeping eveything as strings.
Then noticed their use of  ["%d" (decimal number in the string)] in their original post and at the last just added the extra convertions.
If all they wished to do is change the 10 us then the search and replace with regular expersion turned on will work.
Omar
Message 9 of 15
(5,098 Views)
I just realized that is possible that not necessary the string that is been read will be given in "us" because allows that you type in "ms" also.
So here goes my not-so simple solution: (with B capitalized :P)
Message 10 of 15
(5,081 Views)
