Hi all,
i'm using FPGA to acquire data @1 Mhz from a Custom module in a SCTL an place it in a block memory Target Scoped FIFO1 Block memory of 1023 elements.
What i want to do is acquire a known waveform and and visualize acquired data just to check if data is corrupted or if samples are correctly representing waveform.
I'm reading data from FIFO1 and placing in a MEMORY in another SCTL to not affect 1st SCTL.
My intention in this is to create a one shot reading operation to place 1023 elements from FIFO1 to MEMORY (attached pic).
After this i have another while loop that perform communication with the HOST to read data from MEMORY.
data type is FXP signed 24 bits word with 24 bit integer part.
I cannot visualize anything on the host waveform graph.. Can you tell me why?
I've attached FPGA vi and HOST vi.
Thanks in advance.
