Scaling AD8495 Amp
Having a case of the Math Mondays.
Formula for converting voltage from AD8495 Temperature amplifier is:
Vo=T*5mV+1.5V
OR
T=(Vo-1.25)/5mV
I am able to apply the second formula to acquired measurements, and it appears to be scaling as it should.
The trouble I am having is converting this to LabVIEW Linear Scale.  I just can't seem to manipulate the formula correctly.
Is it possible to create a Scale in Max that uses this formula?
Patrick Allen: FunctionalityUnlimited.ca
(1,370 Views)
Accepted by topic author pallen
y = mx +b
Vo= 5mv * T +1.5V
m is .005  b is 1.5
T=(Vo-1.25)/5mv
T=Vo/.005  -1.25/.005
T= 200 Vo + -250
m is 200  b is -250
Those two equations are NOT equivalent to each other either both are 1.5V  or both are 1.25V
(1,329 Views)
